ewarnerusa
May 28, 2013Nomad
I'm basically wired up like the diagram. 4 gauge from controller to batteries (parallel 12V) with about 5' wire run. Separate 0 gauge wiring for the inverter, also about a 5' run. Both wire runs terminate right on the battery posts. I am using voltage sense wires as well. I have about a 0.1V drop between the controller and batteries which the controller compensates for.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
