BFL13
May 30, 2013Explorer II
Got lost here. How do you put a load on the inverter to knock down the battery voltage below the inverter's high voltage cut-off once the inverter quits at high voltage?
I had that problem with solar (I was on panel-direct at the time--controller had fried) getting voltage too high for the inverter (15v on mine) and ISTR I had to run the furnace--in August!--for a few minutes. Got the furnace to turn on by maxing the temp slider to the top.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
