ewarnerusa
May 30, 2013Nomad
BFL13 wrote:
Got lost here. How do you put a load on the inverter to knock down the battery voltage below the inverter's high voltage cut-off once the inverter quits at high voltage?
I had that problem with solar (I was on panel-direct at the time--controller had fried) getting voltage too high for the inverter (15v on mine) and ISTR I had to run the furnace--in August!--for a few minutes. Got the furnace to turn on by maxing the temp slider to the top.
When the inverter faults, I shut it off with its power switch which is the procedure for clearing this fault. Then I cut the panels off from the controller via the circuit breaker I have installed between them. The battery voltage will quickly drop to a level where I can turn the inverter back on again. Then I can load up the inverter with whatever AC power devices I want which drops the battery voltage even further. Then I can flip the breaker back on to connect the panels to the controller and they contribute to the DC supply to the inverter. If I take off AC loads, the battery voltage will have an opportunity to rise again which it does gradually.
Currently, it can rise right up to the bulk/absorption setpoint (14.40V right now) and the inverter will not fault. But if I have a small load on the inverter while it is right at the setpoint and I unplug that load, the voltage will have the opportunity to do a quick spike before the controller brings it back down to 14.40V again. That quick spike is enough to fault the inverter again on high voltage.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
