BFL13
May 30, 2013Explorer II
pianotuna wrote:
Hi BFL13,
My inverter cuts out at 14.4 volts
If it is cold out, my Blue Sky can get up to 15.5 volts.
If the inverter cuts out I:
1. turn off solar panels
2. turn on water heater
3. turn on solar panels.BFL13 wrote:
PT, please then explain what your water heater does wrt all this in more detail, so even I can follow the sequence.
Thanks.
PT, I missed the part how in No 2, you turn on the water heater on electic after the inverter has quit.
Thanks
