HiTech
May 30, 2013Explorer
BFL13 wrote:
This is beyond confusing :) OK why does the controller take so long to establish that set point, allowing the spike that shuts off the inverter?
--that's the question.
And even if it did, why doesn't the inverter start to work again after voltage drops below 15v?
--It may. But it shut things off. That's the problem
What's all this 14.4v shut off stuff? Back to a bad connection somewhere and voltage drop?
--because it does not shut off quickly enough at the right set point to stop the inverter cutting out. Since it is not fast, this is a work around - keeping the voltage further away from the cutout point as a safety buffer.
