ewarnerusa
May 31, 2013Nomad
westend wrote:
Would installing a voltage regulator in front of the inverter be a solution? I know you'd need one that handles a large amperage but limiting the solar charging just seems like a backwards solution.
Modifying my set points is the free solution using the tools I already have. :-)
I think of my current solution as a way to continue to use the solar rather than limiting it by shutting it off.
