Iceman31's avatar
Iceman31
Help with digital thermostat.
I have been fighting with what should be a fairly simple swap, I am swapping my Coleman Mach thermostat for a Honeywell TH6110D1013 which is a battery operated thermostat. I am attaching a picture of the wiring when I first took it apart. Here is what is coming out of the wall.
Red Wire - which attaches to the grey wire which is attached to GL on Coleman Mach
Yellow Wire - which attaches to the yellow wire on Coleman Mach
Green wire - which attaches to green wire which is attached to GH on Coleman Mach
Blue Wire and a White Wire all spun together which attaches to Blue on Coleman Mach
Second Red Wire - which attaches to Red on Coleman Mach
Second Green Wire - which attaches to White on Coleman Mach
Now on my Honeywell I have these connections
G-
W-
C- Nothing as running off batteries
Y- I assume Yellow Wire
R-
Rc- I assume Second Red Wire as the R an Rc are jumpered.
I am only going to hook up high speed fan so I assume first Red Wire should just be capped and not hooked up. So what wires should be hooked up to G and W on my Honeywell?
I blew a fuse first go around so all help would be appreciated.
Thanks in advance.
Link to image: https://imgur.com/CPsccPk
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
