dougrainer
Dec 01, 2016Nomad
Chris Bryant wrote:
The furnace hookup is a simple relay- two blue wires at the control box. One wire needs a 12 volt feed, turning the furnace on simply closes that relay.
Here's how to put it in diagnostic mode:
http://bryantrv.com/docs2/docs/singlezonediag.pdf
Go to the ROOF AC control board. There are those 2 blue wires. When set to turn the furnace ON, BOTH those wires should have 12 volts. When the furnace is OFF, only 1 of those wires will have 12 volts. IF NONE have 12 volts, your furnace fuse is either blown or you have a wiring problem AT the furnace. Doug
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
