lenr
Dec 01, 2016Explorer III
Mine was defective, period! Would switch into high speed fan before shutting off from low speed fan running AC. No one would design a system like that. They are all annoying because they pause off for a second or two when switching fan speeds from either low to high or high to low. The many button (10 or 12 depending on how you count) thermostat doesn't do the pause and has a tighter on/off hysteresis. But, it takes a control board change to implement. Hopefully the replacement version will fix some of the "non" problems.
