randallb
Aug 14, 2016Explorer
I never assume that the last brake controller setting is the correct one. Every time I hit the asphalt I lean on the manual lever to check the operation of the trailer brakes and set the controller. This is on every trailer, flatbeds or travel, I own. My empty 6x10 aluminum seems to like a max setting of 3.2V with no boost. Loaded all my trailers seem to like 6.8 to 7.0 volts and boost #1. Never assume that the brakes are clean or that the 6.9 V you used last time is the setting that will work with how your trailer is loaded today. Complacency will get you in trouble when you are towing.
Randy
Randy
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
