dougrainer
Aug 14, 2016Nomad
Need to know if your Trailer is 2016 or 2017 and has the LCI Sway Command optional system on your trailer. I doubt your trailer is the problem unless you have the Sway Command. The Trailer brakes react to 0 to 12 volts and 12 volts lock up the brakes. NOTHING on the trailer would produce 12 volts unless you are having a problem with the Emergency Brake away switch. So, your TRUCK would be responsible for sending the Lock up Voltage to the trailer. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
