robstecs
Aug 14, 2016Explorer
dougrainer wrote:
Need to know if your Trailer is 2016 or 2017 and has the LCI Sway Command optional system on your trailer. I doubt your trailer is the problem unless you have the Sway Command. The Trailer brakes react to 0 to 12 volts and 12 volts lock up the brakes. NOTHING on the trailer would produce 12 volts unless you are having a problem with the Emergency Brake away switch. So, your TRUCK would be responsible for sending the Lock up Voltage to the trailer. Doug
It's a 2017 Springdale Summerland with no LCI sway system.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
