time2roll
May 21, 2020Nomad
houstonstroker wrote:As long as both RVs are 30 amp then yes.
How about a 50 amp adaptor that splits the feed into two 30 amp outlets. That way each coach can use up to 30 amps which is plenty and no way to overload.
If you use an adapter to then connect a 50 amp RV the dogbone adapter becomes a fuse.
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Jul 20, 2015
