todintexas
Jun 16, 2015Explorer
Interesting, thank you, I'll need to look into it further this evening. When plugged into shore power, the moment you plug the fridge in it kicks the GFCI at the pole. On one occasion, it kicked the GFCI both in the coach and at the pole simultaneously. It was running correctly on the genset, but only for a short time. I'll check polarity, leave it run for a while on the genset, then pursue the troubleshooting avenue suggested. I see where the 30 amp shore power plug has been replaced,just the plug and not the cord, I assume that any bleed through inside that repair could cause this also?
