dougrainer
Jun 16, 2015Nomad
todintexas wrote:
Thanks Doug, that will be my first avenue of troubleshooting this afternoon. If the source of the trip is the heating element, and it goes away when they are unplugged, any idea why the fridge would operate normally on the genset? The ice maker is not plugged in, it has a separate 120 plug that I have not even attempted to plug in.
There are 2 models of the 1200. 1 model has the separate Icemaker plug and the other the 120 is spliced into the 120 wiring of the refer. IF the refer is OFF, then the 120 Heat Elements are not activated. So, if they were bad, they should not trip the GFCI if the refer is OFF. But, that is why I suggested unplugging the Heat elements from the control board. Take them out of the loop. Doug
