westend
Jun 18, 2015Explorer
todintexas wrote:I don't know what you have for cords or how you are connecting the fridge. The scenario you describe (runs on genset--trips GFCI on shore power) may indicate a neutral-ground problem. Yes, if you have a splice, that would be one of the first things to check. You can check the integrity of your cord sets to make sure there is continuity where there should be and no shorts/opens.
You are talking about the shore power cord, correct? The cord itself is in excellent condition, nothing loose at the plug. However, there is a splice between the shore power cord and the distribution box. I'll take that apart this evening and make sure there are no obvious problems.
