So I got myself a new camper, and i didn't check the fridge before I bought it. Now I can't get it to work in any setting. I tried in propane and in 110. The old owner said it worked last year. The un...
10 degrees is not good. If you disconnect the tiedowns, you should be able to use the jacks to level that much pretty quickly. I'm assuming you didn't bring blocks or boards of any kind.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
