TimnJo
Mar 24, 2022Explorer
I have an in-bed auxiliary tank. Initially I bought the kit with the hose, manual valve and tee with a 'rollover valve'. This setup worked on my 2010 Chevy for the most part but occasionally would overfill the main tank, I never figured out why and lost fuel more than once, eventually causing me to take out the roll-over valve and just use the manual valve for control. That worked fine except that we'd pull over for lunch and to open the valve and if I didn't open the valve first we'd get back on the road, realise the mistake, and have to stop again, sigh.
I got a new truck and when I moved the tank to it I installed a 100% duty 12V solenoid valve with the power switch in the cab. The switch is illuminated when on and is in line of sight and is also hooked up to accessory power so if I forget to turn it off at destination it won't drain the aux tank onto the ground.
My previous truck would sometimes detect that the fuel level wasn't dropping and the tank level indicator would drop to zero, resetting on cycling the ignition key to off. This hasn't happened with the new truck.
HTH, Tim
HTH, Tim
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
