YC_1
Nov 10, 2014Nomad
The manual should show the hookup for the ice maker. IF the line is going up high and that end is loose it just inserts into a grommeted hole. There is not supposed to be any pressure build up on the line but if the ice maker over fills due to improper adjustment an ice blockage will cause the end of the hose to plug and the pressure when the ice maker cycles the water on will pop the hose out.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
