dougrainer
Nov 10, 2014Nomad
1. ANY person that calls himself an RV Tech will do plumbing. He is a scam artist and he does not have the resources to sue you or anybody. TRUTH is defense to slander. As long as you truthfully state what happened he will not try to sue you. YOU on the other hand may have recourse in the State of Florida. I do know that you have to be licensed in the state to do any type of home improvements. You can also sue HIM in small claims court for what he did.
2. The water line is easy to reinstall. If the line came loose at the rear bottom. Doug
PS. If you have text messages, print them out in case something happens in the future. You best bet is to pay someone to fix your problem and have them document the cause of the failure so if you decide to take him to small claims court you have the text messages and the documentation from the correct repair. The odds are, even if you go to small claims court, the so called tech will not have any assets or anything to force him to pay, BUT, if you win, then you can truthfully tell others what happened and you have the documents to prove it.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
