westend
Jan 26, 2017Explorer
jrrichar wrote:You should, at a minimum, either monitor your battery system use or calculate closely. A solar charging system is tailored to your use. With an upgrade "path" you will know how many panels are needed to recharge your batteries since you will have a monitor to give you those measurements. Depending on where you are located, a good rule of thumb is to install 1 watt of module for every 1 AH of capacity.
Weighing all the pros and cons I'm considering the following:
1. 2x GC-2 6V Trojan or Interstate FLA batteries
2. A battery charger of some kind (IDEAS PLEASE)
3. Bogart Trimetric Battery Monitor (so I know exactly what's going on)
4. Anything else not mentioned/known that could provide advantage for electric system
All of this being said I DO want to upgrade in the next year or so to solar because I don't want to have to rely on the generator when the weather is good. Turning on a generator and listening to it just to charge batteries is not ideal. However, I'm not made of money and do to my concerns about heat/cold my priority has to go towards spending good $$ on the generator and forgoing solar in the present.
If someone has thoughts to the contrary or items they have found of use please list them
If you haven't visited these sites, it is good education about 12 V systems: 12 V side of life,
Battery University
Having RV issues? Connect with others who have been in your shoes.24,331 PostsLatest Activity: Nov 04, 2025
