opnspaces
Mar 20, 2017Navigator III
Have you used your meter to check for 12v power at the distribution panel? If you pull the cover off the panel you should find the battery positive and negative connections. See if you have battery voltage at the panel. Don't just look for 12 volts. If your batteries read 12.67 volts you should also see 12.67 volts at the panel.
Also check and make sure you have a good ground connection at the battery and at the frame.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
