mdock2's avatar
mdock2
HELP!!!!!! with last step of inverter install
I'm finishing up on installing the AIMS Power PWRIX120012S 1200 Watt Pure Sine Inverter, with Built In Transfer Switch. i have installed a sub panel, and should the sub panel be Bonded or not.
Thanks for your help...
marty
  • What exactly do you mean by "bonded" ? In Rvs the main dist panel for the 120v breakers is not bonded. The shore power source panel the pedestal receptacles are on is the bonded one.
    So your sub-panel from the inverter needs to be carefully defined as to what you are doing.
  • "boned"???
    Or did you mean "bonded"??
    If you mean bonded, then the answer is no!! NEC specifies a "sub panel" is to have isolated neutral bus bar, carried back to the main panel.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
