Snowman9000's avatar
Snowman9000
Help with shunt ammeter
I just got one of these from ebay:
I am trying to read V and Amps while charging a battery on the bench. I have the shunt attached to the negative battery post, and the charger clamped to the other end of the shunt. I've tried both shunt positions for the yellow and black wires, and all I get is a 0 reading for amps, even with 7 amps flowing as measured by my clamp meter. The volts read fine.
There are calibration pots on the back side. The voltage one works. The amps one doesn't move the reading from 0. The shunt is passing current. The wire pigtails have continuity back to the plug.
Before I attempt to contact China Tech Support, based on the wiring diagram, how should I wire the yellow and black to measure battery charging?
Any suggestions on how to troubleshoot?
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
