WAM's avatar
WAM
Help with trailer brakes
Actually, my brakes work fine (on a car hauler trailer). Really.
But my 2012 Ford F350 systems monitor is not seeing what it needs when the trailer is hooked up and issues continuous inappropriate now-disconnected/now-connected alarms. And yes I've done all the appropriate troubleshooting looking for mechanical issues inside the drums, chafed wires, bad grounds, bad 7-ways etc.
I notice when I put an ohm meter across my trailer brake wiring I get 28 ohms (just one axle braking). I'm wondering if that's typical, seems high to me. Request for those of you with VOM's to check what resistance you find looking into the trailer 7-way, between the brake power wire and ground.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
