larry_barnhart
Oct 14, 2013Explorer
If the check valve is bad no water enters the water heater. I just replaced ours 2 days ago. I removed the check valve 5 years ago because the rv stores were not open for a replacement. You can remove yours and gut it so it is a straight flow like a pipe nipple.
chevman
chevman
