Old-Biscuit
Oct 14, 2013Explorer III
IF you have 3 valve system on water heater.....no check valves
BUT if you have a 2 valve or 1 valve system then there is a check valve on hot water heater outlet.
It is internal of the nipple on tank........hot out is at top.
They fall apart and/or get clogged with scale/debris....then no hot water leaves tank
Check valve is only needed when bypassing water heater....winterizing or if doing repairs to water heater
