Bill_Satellite
Nov 01, 2013Explorer II
When in the EQ mode the lights should be sequencing left to right over and over again. It will continue to do this and charge at the higher EQ rate for 8 hours.
The bad news is the acid/sulphate smell. This should not be happening and usually indicated the batteries are boiling (over or not) and that's not good.
Was there a reason you want to do an EQ or is this just a once a year routine? 1185AH? Are you sure about that? That's a whole lot of batteries!
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
