CREATO
Nov 02, 2013Explorer
Bill.Satellite wrote:
When in the EQ mode the lights should be sequencing left to right over and over again. It will continue to do this and charge at the higher EQ rate for 8 hours.
The bad news is the acid/sulphate smell. This should not be happening and usually indicated the batteries are boiling (over or not) and that's not good.
Was there a reason you want to do an EQ or is this just a once a year routine? 1185AH? Are you sure about that? That's a whole lot of batteries!
I have 6 exide 6 volt golf cart batteries 186AH each unless I had a ytpo on first post totall AH is 1116AH and I generally EQ. once a year befor I put it in the shed for winter. UNless I am not figuring totall AH right
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
