dougrainer
Feb 11, 2014Nomad
BoonHauler wrote:Kiwi_too wrote:
BoonHauler, Thanks. I actually started with the RV Doc. I found the HepvO Manual. I see some of their claims, like the seal will remain when not used for a long time, but remain skeptical. They say it is less likely to clog and I can see that. When it does clog though, how do you clean it? Do I use a septic safe Drano? Will that hurt the membrane? If close to the drain hole, I might use a plastic Zip-It drain cleaner?
I see that in your OP you posted a link to Drain Master. I've been working with them on some of my Sanitary Sewer items. Give them a call as they're VERY knowledgeable in this deparment, it's their business.
Ask for Doug (owner), he's a really nice guy and will answer all the questions you have. Tell hime BoonHauler sent you.
I am NOT an RV owner. I have been a Professional RV Technician for 34 years and Master Certified since the first year they started a Certification program. That is the basis for my postings and comments. Doug
