BoonHauler
Feb 11, 2014Explorer
Kiwi_too wrote:
They say it is less likely to clog and I can see that. When it does clog though, how do you clean it? Do I use a septic safe Drano? Will that hurt the membrane? If close to the drain hole, I might use a plastic Zip-It drain cleaner?
Kiwi:
As for the potenial for any sink trap to clog I myself plan on using a good basket strainer. This way you'll keep most of the food solids out of the gray water system and keep your GW tank a happy camper :)
