as a little history, I replaced the 13 amp breakers fuses with 20 amp. I know the danger behind this but if this wont run my RV air then it does me no good. So with the 13 amp I could run RV air for about 10 minutes and it would trip the breaker. With the 20 amp it wont trip. I have about 5 hours on it now and as of now no problems. BUT... it's completely unbalanced. It's pulling max form one side of stator. I can only imagine this will shorten it's life probably more then the 20 amp breaker change. When air is running I can check the volts at the side the air is plugged into and its at about 108 volts and I can check the unused side and its at about 130 volts. So I'm guessing the AVR is trying to adjust for the draw on one side and over volting the other.
If I can get parallel at 70% I would be happy as the draw will be from both limiting the major unbalance I have know.
At least that was the plan.. lol
