DrewE the measurements are at the terminal block. I removed all the other wires to the plugs. All I did was swap around stator wires at the terminal block.
The two whites are not connected when trying the parallel. The two whites are connected up towards the 240 plug and I have those wires disconnected from the terminal block when testing.
There are two sets of wires coming out of internal windings. They are separately sheathed. One set is red and white and they check out with continuity the other is black and white and they check out with continuity.
I think I am wiring it correctly for parallel. My thought is it might be the AVR keeping this from working. I don't know if the AVR needs to see the neutral. ???
other thought is maybe I cant stack the wires at the terminal. Maybe I have to use separate lugs and run a short wire and connect them together farther down the line. If that makes sense.
Not sure. I was hoping someone on here has had this issue before and could give some advice.
