Dusty R wrote:
I have a Montgromey Ward 4000 watt belt generator that has a switch to change to 4000 watt 115v and no 230v, or 2-2000 watt 115v and 1 4000 watt 230v receptacle.
I'll see if I can find the manual tomorrow. It has the wiring diagram in it.
Dusty
Dusty,
I am 100% certain that your old school Monty Ward gen head will not be wired anywhere the same as these newer Chinese heads.. Most of the old gen heads often did not have AVR, kind of makes a difference..
I have a 10 yr old Chinese import which has AVR, it is 120V only.. I did look at rewiring with a switch to give me the option of 120/240 but the wires I need to get to are buried deep inside the gen head, they are not brought out as separate wires on mine.. Just too much work to tear it down that far.
