3 tons wrote:
So I kinda of the belief that the ‘non-programmable’ Easy-Start (as good as it may be in common applications) is not syncronizing well (or compatible??) with genny on Eco (due to cycling), and the inverter back up takes over without a hitch...
You keep referring to your soft starter kit as an "Easy Start" which is the proprietary name for Micro-Air's soft starter but I thought you had mentioned elsewhere your kit was manufactured by Hyper Engineering, called Sure-Start - no? Based on the detail you've provided I'm still of the opinion that this soft starter may be part of your problem ... have you discussed your problem with the manufacturer? :@
