harold1946
May 26, 2013Explorer
HiTech wrote:harold1946 wrote:HiTech wrote:
Of course it can. There are many ways to measure efficiency. Watts output at standard test conditions/ energy out vs energy in in one very lab specific set of circumstances is but one possible way. Cost efficiency per watt is a valid measure. Efficiency in total watts generated per a particular roof space (which will include packaging efficiency as well as panel energy conversion efficiency) is another.
Google "cost efficiency" in quotes.
Jim
I would respectfully desagree. Efficiency is one thing, cost is another. The most efficient panels are also the highest price per watt.
There is only one standard used in the industry for measuring the efficiency of solar panels, and has nothing to do with what the manufacturers price is.
When someone says efficiency in regard to a solar panel I would agree. But cost efficiency is a very standard term across technologies and has a clear and valid meaning as well.
Jim
You are playing with semantics. The OP's question was quite spacifically about solar panels. Maybe you should read the question and try answering that, instead of trying to confuse the issue. :S
