christopherglen
Dec 24, 2013Explorer
When searching for a way to charge the batteries on my trailer, to run the trailers inverter/charger to power the 120vac mini fridge, I tripped over these..
They make 10, 20, and 50 amp versions. Basically a charge pump from one 10-15 volt input to a 12 volt battery. Intended for the batteries on lift gate equipped trailers. It *should* work to force feed up to whatever its rated amperage into your batteries overcoming slight shortages in alternator voltage or wire gauge.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
