Almot's avatar
Almot
Explorer III
Dec 05, 2018
High pressure propane filter
Have This one installed on the tank. Prevents any cr-ap from getting into my most vital equipment - fridge and catalytic Olympian heater. Now that I got auto-changeover regulator, it looks like I need to buy another $40 filter.
I'm sure the answer is "no", but is there any way to use one filter for both tanks with auto-changeover? High pressure filter, it needs to be on the tank.
  • Almot's avatar
    Almot
    Explorer III
    I heard from more than one person that it does stop some oil.
    Estimado senor Mex - how do you suggest to check from time to time the status of cotton guts in a filter that can not be open?
    (Time2roll - in a village 150 miles from a midsize hardware store and 300 miles from Home Depot things that don't matter elsewhere, may become important).
  • MEXICOWANDERER wrote:
    A lot more than forty dollars in plumbing could do it. Not worthwhile. Remember the cotton or rayon soaks up oil as well as dirt so check it's status accordingly. A downstream 11" water column gauge tells me when there is a problem.
    Exactly...
  • It will stop SOME of the oil. Otherwise it wouldn't get soaked with oil.
    On my system down here, my old sole LPG bus and one ton Chevrolet, I had reservoirs for oil to drop out of the gas followed by filtration. Over a period of say a month or two it was not unusual to drain in excess of a pint of oil. It is a matter of where their system picks up suction for pumping and how faithfully they check for contamination and blow down for flushing.
    A lot of what mechanics see with contamination can be compared to operating an engine oil filter for two hundred thousand miles without servicing. They see sludge and dirt. It should not be claimed the filter is not doing it's job. The problem is the filter is ignored for years.
    In a refinery, LPG cannot be processed devoid of lubricant. Secondly, odorant is a liquid injected into the process stream it is not a gas.
    I accumulated over 200,000 miles in the seventies and eighties running LPG exclusively. I always had at least fifteen filters on hand. Dirty filters passed contamination and clogged a vaporizer or Imco 425 carburetor. And that is something a person does not want to deal with on the side of the road.
    The filters are utterly unsophisticated.
  • As the manual states for this filter, it will NOT stop the oily residue contaminant that causes LP problems. Debris?????????? Not a problem at all. If there is any possible trash in your low pressure LP lines, it was there from build and did NOT come from your tanks or regulator. I have 38 years RV technician experience and 38 years of Texas RRC LP training and have NEVER seen such a filter and have never had any reason to use such a filter. I would not install and use it. Doug
  • If it is that important then yes you will need two.
    Never knew this was an issue.
  • A lot more than forty dollars in plumbing could do it. Not worthwhile. Remember the cotton or rayon soaks up oil as well as dirt so check it's status accordingly. A downstream 11" water column gauge tells me when there is a problem.
