pianotuna
Oct 23, 2015Nomad III
Hi Gordon,
No there is no voltage sag. 125 amps I've seen. 127 is when the fets over loaded. I did have the inverter on. When I restarted I did so with the other loads reduced down to just 325 watts. The fets did not over load but as quickly as I could I reset the remote to use only 13 amps to prevent it from doing so.
What sort of batteries do you have? AGM's have much lower internal resistance, so I'm postulating that they wanted even more than 125 amps--which is the limit of what the magnum can do.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
