MrWizard
Oct 23, 2015Moderator
PT
It could be , because you were running the heaters and the MW from inverter
The magnum could not maintain the voltage setting
It tried to crank up the amps to maintain the voltage ?
You did not specify if those items were running directly from the genny or from the other inverter
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
