landyacht318
Oct 23, 2015Explorer
If you can change the output voltage, you can change the charge output amps.
But you might have to keep twiddling voltage upwards to keep it close to the 125 max output.
I wonder if this is something that could be attenuated with more ventilation.
The temp of my meanwell at 40 amps is quite high after 45 minutes at full output, but once amps start tapering, at about 35 amps the heat produced drops drastically.
Add more computer fans, add more heatsinks, if possible.
BFL13, 156 amps........ That's freaking awesome.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
