MrWizard
Oct 23, 2015Moderator
yes..i know about load support
but it does not charge while doing this
anyway you answered the initial question
everything, charging and heaters was on the generator
sounds like the magnum is out of adjustment
it should NOT exceed its output rating anytime
what if you were on 30amp or 50amp shore power
you did change the setting to AGM batteries right
something needs to be adjusted someplace, maybe by factory service personel
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
