dougrainer
Sep 07, 2015Nomad
If he has 19 volts at the refer, then he should have 19 volts everywhere else, even at the battery. UNLESS, someone has wired a solar charger direct to the refer, because 19 volts is about what an unregulated(not connected to a 12 volt battery) solar charger will put out. Doug
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
