christopherglen
Sep 07, 2015Explorer
Slap a meter on the battery. If it is 16+ volts, pull it and go to an auto parts store, and have them test it. if it is between 12 and 16 volts retest the leads on the fridge. If it is less then 12 volts, look for blown fuses, loose or disconnected wires at he battery, converter, and DC power center. You may also have a battery disconnect switch, check for and make sure it is NOT disconnected (the converter is charging the battery).
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
