Chris_Bryant
Sep 07, 2015Explorer II
dae06 wrote:Chris Bryant wrote:
A 2000 Sportsmen could well have a Magnetek 6300, which separates the battery from the unregulated main feed.
It is a 6300, but I guess I do t know what that means? Is that good or bad? Sorry, I'm not very well versed on this ;-).
Btw, I was camping this weekend, re-tested everything, and all voltages were within specs. But later on I got the " over Vdc" error on the fridge. Unfortunately I was not able to test it with a volt meter.
That's a pretty rottenc converter, and should be changed, but in the meantime, you can find the fuse the refrigerator is on and move the wire down to one of the right hand, "filtered" circuits- these are always hooked to the battery, and are regulated. The main outputs are not regulated- so if the park power is high, the DC will be high.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
