KD4UPL
Mar 30, 2014Explorer II
The Outback controllers are excellent. I've never had any trouble out of any I've installed. The Xantrex XW 60 amp unit is very similar and also good. It has a larger heat sink and no fan. It is usually a bit less expensive than the Outback 60 amp.
MidNite Solar makes some nice units but they're probably more than the Outback. The Morningstar is probably the cheapest.
My preference would be Outback, that's what's in my own house. Do you have plans of adding a nice large inverter/charger to your rig? If so, and you use the Outback FX28212M, you can use the same MATE (remote display/control pad) for the inverter, charge controller, and battery monitor.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
