GordonThree
Mar 31, 2014Explorer
A few of the panels I am looking at...
I call her "Big Bertha"
290w poly
Nice price on a mono panel
270w mono
Jeff, I have about 900 amp-hours of battery and use about 200 amp-hours in a 24 hour period... I'll use my 2800 watt inverter to run the MW, waffle maker, electric kettle, as well as small stuff like the tv, laptop, etc.
Typically I can recharge with a 3-hour generator run with my Yam 2000, as long as I don't do much electric cooking while the recharge is running. I'm a heavy user of electricty and don't want to bother with conservation, so the more watts I can squeeze out of the sky, the better :)
I'll read up on the Rouge, but it looks to be undersized as well, by my math I'm really looking at atleast a 50 amp controller ... 500 watts / 12 volts = 42 amps, 600 watts / 12 volts = 50 amps.
Thanks for the link on the panel; it looks like they just built the shipping cost into the price of the panel... 250w should be closer to $225 - $250 plus shipping
The price is right on the eco-worthy, but with a maximum of 20 amps, a 250 watt panel would be right on the edge and the 270-290 watt panels would be too much. Sure, I'll probably rarely hit the max rated output of whatever panels I get, but I wouldn't want to hamstring the system with undersized controllers. Good points regarding parallel controllers; pushing that last few percent of capacity back into the battery is the slowest, and likely one panel's output would be all the battery would accept.
290w poly
270w mono
Unyalli wrote:
How much battery are you trying to charge and how much power do you expect to use each day?
-Jeff
pianotuna wrote:
Hi Gordon,
Try this: 250 watts with free shipping
BFL13 wrote:
Another aspect for Absorption and Float is that by then, your battery acceptance rate in amps is so low that one set of panel/controller could do it all anyway, even if it happened that one controller was at lower voltage than the other so it had dropped out of play by then.
These were "series" type controllers, not "shunt" type. With shunt type you have that on/off shorting of the panel where perhaps two of them could get out of synch, don't know. Each has its own panel anyway in this idea. With the series type that did not arise. MPPT controllers AFAIK are sort of bucked up series types---somebody maybe can confirm/deny that ????
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
