BFL13
May 13, 2015Explorer II
Is 56v a "48v" panel? Some, not many, controllers will do 48-12 to a 12v battery.
Advantage low amps on the panel to controller wire path, so the wires can be thin. Disadvantage, the lower efficiency bucking from 48-12 in the controller.
With the panel free it is all math to see if the controller cost makes the whole set-up "worth it"
Stick houses use 48v and there are now small but useful 48v inverters they get for them. Don't know a lot about it--might be useful in an RV?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
