ckwjl wrote:
SDcampowneroperator wrote:
1" hole, plug it after with a boat transom drain plug. A rechargeable drill does not have enough voltage to electrocute anyone, an electricians 'step bit' will make a clean hole through thin material.
A pump out service with a vacumn honey wagon makes a lot more sense, if you can get one, if they can get a suction hose into the tank
How did you come up with the notion one would believe someone could be electrocuted from using a rechargeable drill?
A previous poster suggested electrocution from a drilll as a concern. Read the whole thread
