HarryB1's avatar
HarryB1
Holes in Fiberglass Roof
Can someone suggest what might be happening with the fiberglass roof on my 2005 Newmar Kountry Star 5th wheel? I've owned it for about a year and a half, and see no evidence the roof has ever been coated. When I washed the roof about 3 months ago I'm sure I would have noticed these cracks if they'd been there, so this situation developed relatively recently. The trailer is set up permanently in Florida and there are no overhanging branches.
Click For Full-Size Image.
This hole is about 1/2" wide, and this is the only place on the roof where I see these types of cracks.
This second picture shows an area some distance away where I discovered a brownish spot similar in color to those in the first picture, but there were no cracks. I began to scratch at it with my fingernail, and after discovering the surface felt soft, it came off with very little effort, resulting in this hole.
The rest of the surface of the roof seems to be quite solid. I can put an indent into the fiberglass with my fingernail, but nowhere does it feel soft like it did at this spot.
Is this an indication the whole roof is beginning to fail, or something else?
  • First evaluate the extent of the damage by removing all soft material, by carefully sanding until solid material is clean.
    I use PC-11 epoxy that is a 2 part ..(A+B) this mixture will result in a (white) hard filler.
    all surfaces must be clean prior to any epoxy application
    I Would have the entire roof cleaned, and sanded then the roof re-coated with something like Flexseal.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
